RB2 drumkit problem
YoungGun21
Anybody else have RB2 drumkit problems? Mainly referring to the pads themselves. My red pad (well... the soft rubbery type material on it) came loose and popped out. It is basically half off and gluing it back on would cause it to bubble (which is bad).
What are my options here?
There's a warranty on this stuff I believe. Check out the rock band website for instructions on how to get it fixed.
I RMA'd my kit when that happened. No problem returning it. On my replacement kit I put the official silencers on there day 1. A hair less rebound, but the pads are still in perfect shape. If you are out of the brief warranty period consider these replacement heads:
http://goodwoodmods.com/
$99 right now
