JonTheBaller
My computer is very quiet in general... I'm not OCing so I don't have any hard core fans. Sometimes, however, I hear a rattling/vibration type noise from the computer case. I think it's possible that the IO panel, since it is thin, might rattle, or it could be the screws or all the things I plug into the back. Does anyone have any suggestions that would reduce rattling? If I put the case on some foam instead of the hard ground would that help at all? Thanks.
