Rather strange problem burning CD-Rs with Nero and Asus 5224A
CotswoldCS
384
Odd one this...
Windows XP SP1
Nero Version: 5.5.9.2 (Nero Express)
Asus 5224A IDE CD-RW
80Gb IDE HDD
I can copy a CD no problem. When I choose a selection of files from the hard disk and try and burn I get the following error with Nero Express:
15:47:58 #13 Phase 24 File dlgbrnst.cpp, Line 1560
Caching of files started
15:47:58 #14 Phase 25 File dlgbrnst.cpp, Line 1560
Caching of files completed
15:47:58 #15 Phase 36 File dlgbrnst.cpp, Line 1560
Burn process started at 32x (4,800 KB/s)
15:47:58 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1967
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
15:47:58 #17 Text 0 File Mmc.cpp, Line 16267
Set BUFE: FlextraLink -> ON , Fixed Writespeed : ON
15:48:07 #18 SCSI -500 File Cdrdrv.cpp, Line 1406
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02E30000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
15:48:07 #19 CDR -500 File Writer.cpp, Line 330
SCSI/IDE Command aborted
15:48:07 #20 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
15:48:07 #21 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
15:48:19 #22 CDR -201 File WriterStatus.cpp, Line 187
Invalid writestate
15:48:19 #23 TRANSFER -18 File WriterStatus.cpp, Line 187
Could not perform EndTrack
15:48:42 #24 Phase 39 File dlgbrnst.cpp, Line 1560
Burn process aborted
15:48:42 #25 Text 0 File Scsicmd.cpp, Line 383
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I have tried burning at different speeds, using a different brand of CD-R. This is a new machine and as such is the first time I have tried to burn a CD. If there is a problem what could it be and how do I pursuade the manufacturer that it is a hardware not software problem?
One curious thing is that my HDD is detected as a SCSI device when in fact it is a standard IDE drive using standard PATA Cable.
CotswoldCS
384
Anyone???
Please? I'm not sure what to do to resolve this problem. The machine's under warranty so I am concerned about upgrading the Firmware on the ASUS drive. Any suggestions?
newbiepcuser
4,474
I don't have a solution.
But you might try the forums on cdrinfo or storagereview.com for help maybe.
