Bubbasuwannee
I have an MSI Neo2 Plat. board with an A64 3000+ running at 2.4GHz. Initially I was using a TT Tower112 heatsink with a TT UFO 92mm fan and AS5 thermal compound. The temps were around 42 degrees at idle and 55 degrees full load. Well, I swapped that out for a TT Pipe101 Heatsink using the same fan and AS Ceramique thermal compound. Applied the compound using the directions on AS's website. Initially temps looked a lot better, idling around 38 degrees and 49 degrees full load. The temps are suppose to drop over time, but mine are increasing. Now I'm running 44 degrees at idle and 56 degrees full load. What gives? I understand that my temps are still within tolerance, but I still prefer to run below 40 degrees at idle and below 50 degrees under full load. Any thoughts on this? Thanks.
Christian J. Grest
Christian J. Grest
