Rate my wire management
thesob40
121
Well, I've been working on my wire management for sometime now and i think I've gotten it to a good point. What do you guys think? Good or bad?
Before
After
SparkyJJO
13,357
7
Its definitely better. Also good to see that you got the heatsink mounted properly afterwards ;)
Here is an idea to maybe help tidy up a little more - that blue cable going to your vid card, Like this, use zipties to hold it in place if you need to. Just an idea. But looks good otherwise :)
aigomorla
21,134
3,671
want some advice?
Try to drill a hole right next to the mobo power plug.
And route your cables from behind like this:
http://i125.photobucket.com/albums/p73/aigomorla/IMG_0574.jpg
Take a look at my main rail thats sleeved. I gutted a hole in the back plate and routed all the SATA cables + power cables from behind to the conntectors on the mobo.
It just looks messy because i didnt finish zip tying the loose cords and i have water tubes running.
But i hope you gert the idea.
But on another note: Great job! i bet that felt good too when you finished :D
Boyo
1,406
I think it looks great. Very clean and easy to get to all the hardware. Nice job.
thecoolnessrune
9,673
583
How are systems that clean inside? That looks amazing.. I have 3 HDDs and 2 optical drives... and my system looks like a bomb went off inside. Worse part is I have no idea how to clean it all up..
aigomorla
21,134
3,671
ahhhhhhhhhhhhh.... looking at your armor, is making me miss mine....
Well soon that is... i aquired a U2-UFO :]
Remedy
3,981
Originally posted by: thecoolnessrune
Originally posted by: Remedy
Why do you have four exhaust fans in your system? :confused:
Because its better to suck than blow! Duh!
:p
Are you overclocked or something? Four fans is a lot and seems very inefficient air flow or pressure wise to the system.
thesob40
121
first...i have two exhaust and two intake...and i am using four fans because its what i paid for...
edit--make that 3 exhaust...forgot about the pci exhaust lol
