Rate my system and tell me better prices/options plz
RyuRobD
Getting this system for a friend, would like suggestions. They're all from Newegg.com unless indicated otherwise:
2 x Thermaltake tri-color cold cathode light - 15.99 x 2: 31.98
Chieftec Green Case with 450 W generic PS - 92.99
Cd-Rw - FAR from officemax
Lite-on Dvd-rom 166S - 36.99
2 Antec Tricolor case fans - 19.98 for both
Floppy - 10.00
2 x 120 GB WD SE HDS - 110.00 each
Logitech Cordless MX Duo - 83.00
2 x 512 MB Corsair Value PC3200 RAM CL2.5 - 97.00 each
Sony CPD-E440B Black 19" CRT - 309.00
Asus P4P800 Deluxe - 136.00
HP PSC 2210 Printer - 275.00
Intel 2.4C - 175.00
Win XP Pro OEM - 143.00
Audigy 2 Platinum - 167.00
Logitech Z-680s - 290.00
ATI AIW 9800 PRO - 412.00
Subtotal - 2586.93
Shipping - 56.10
Total - 2643.03
Any suggestions would help
Well, I would change quite a few things, as I think you could pay a LOT cheaper. But if you can afford it, why not? Is your total of $2,643 high to you, or is it just right? If it's high, then I'll recommend some stuff. Otherwise, if price isn't a factor, there's not much I'd change, except the ATI for an Nvidia.
well, i want this hardware setup, and i decided to go with the ati aiw so i could use the aiw functionality. However, are there any recommendations where I could get any of this stuff cheaper online? The main thing is that I want a better price for hard drives online. However, I do want this setup unless there are some comparable changes i can make.
Wow expensive as hell, but I don't see you finding a place that sells the parts cheaper. The only thing you may want to consider is getting a named brand power supply unit for your case. Antec is the way to go.
