I'm looking to build my own desktop. I have put together a list of components and current prices as of today at Newegg that are in my price range ($400-$500). How does my configuration look? If I can get it a little cheaper (closer to $400 than $500), that would be great. Here is my info:
Quiet would be good. Future proof would be good too. Will probably add a dedicated graphics card down the road once I get frustrated with the integrated GPU on any mobo. Will also probably put Linus Ubuntu 10.04 just to mess around with, may want to add Windows 7 for a dual-boot machine down the road.
This is what I have initially from Newegg. How is it looking?
Phenom II X4 955 Black Edition 3.2GHz CPU ................................ $160
http://www.newegg.com/Product/Produc...82E16819103808
Asus M4A78T-E ATX Motherboard ............................................. $115 ($20 Mail-in rebate)
http://www.newegg.com/Product/Produc...82E16813131366
Kingston HyperX 2GB DDR3 1600 Memory (2 kits for 4GB total) ... ... $114
http://www.newegg.com/Product/Produc...82E16820104136
OCZ ModXStream Pro OCZ500MXSP 500W Power Supply ......... ........$60 ($20 Mail-in rebate)
http://www.newegg.com/Product/Produc...82E16817341016
Cooler Master RC-690-KKN1-GP Case .......................................... $60 ($10 Mail-in rebate)
http://www.newegg.com/Product/Produc...82E16811119137
GRAND TOTAL ................................. ...................................$509 ($459 after rebates)
1. What YOUR PC will be used for. 1. Multimedia (photo, video viewing & transcoding. 2. Multimedia server to show photos, video, etc.. to other connected devices in my house. 3. General gaming
2. What YOUR budget is. $400 - $500
3. What country YOU will be buying YOUR parts from. USA
4. IF YOU have a brand preference. No preference
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are. Monitor (Dell 24" 2408), Keyboard, Mouse, Optical Drive & Hard Drives (I have two 2TB WD Green WD20EADS recently purchased, unused still).
6. IF YOU have searched and/or read similar threads. Yep
7. IF YOU plan on overclocking or run the system at default speeds. Overclocking does appeal to me
8. What resolution YOU plan on gaming with. Not a primary concern.
9. WHEN do you plan to build it? Next 2 weeks
