Rar help
Kevin1211
1,582
well, i have a video, but i want to send it to my friend. Its waay to big to send it as one big file, so i want to send it in volumes. how can i split the Rar file into smaller files (volumes)? thanks in advance
BlueWeasel
15,944
475
If you're using WinRAR, just simply fill in the "Split to Volume, bytes" space with the max number of bytes you want for each file. Most any other RAR compression utility (like 7-zip) should have a similar capability (although it probably won't be exactly the same).
