Let's say you installed 2 x 80GB SSDs in RAID 0 using the Intel RST 9.6 drivers. You used it like that for a while and now want to go back to using a single drive setup. Would this plan work (yeah i know I have to try it to actually verify, but I figure I'd bounce this idea in the forum first):
Make a backup image of current setup using Acronis TE 2011
Reboot
Go into Matrix utility, break RAID, reset drives to 'Non-Member disks"
Save
Using Acronis Boot Media to restore image to single 80GB SSD
What do you think?
I am figuring this should work because I have some "Non-Member disks' now along with my 2 x 80GB SSD array and when I benchmark using AS-SSD, the RAID array and single drives both are listed as using 'iaStor'.
Is there any downside to doing this versus using the AHCI driver?
Thoughts?
Reboot
Save
What do you think?
Thoughts?
