Range extender problems.
btcomm1
943
Has anyone ever been able to use a range extender succesfully? I'm sure someone has but I set this up. First off even though it's only about 20 feet away from the router the wan light on it keeps going on and off. Second is the computer will connect and definetly has a better signal then with just the router, then it will disconnect and reconnect over and over and then the computer connects to the orginal router and has the low signal again.
I have a feeling the range extender is bad, I don't know why else the wireless light wan light would go on and off os much being so close to the router.
Anyway what do you think?
