- May 5, 2002
- 96
- 0
- 0
Jeez, it's so annoying. My old motherboard had failed so I went out and got a new one the a7n8x-x and got new ddr memory too since the other mobo was running that old via 133a chipset or whatever where you would just use 133 ram.
Anyway, I put it all back together and now I keep getting random system freezes. The screen just locks up and nothing except for reset or power will get me out of it.
It always seems to happen at different times. The temperatures are good and I'm using XP Pro so I don't think either of those are an issue. I've tried different BIOS (1005, 1007), I've rearranged pci cards, and I'm still getting lock ups.
I'm just wondering what it could be.
A friend of mine had what looked to be the same problem a while back with a computer that he put together and he swapped out EVERYTHING (except for processor) with different items: sound, ram, video, motherboard, hard drive, nic, and he couldn't get his to work.
Am I destined to fall victim to the same result?
What would normally just cause a random system freeze?
Specs of my old school system:
1 ghz Thunderbird
Asus a7n8x-x
512 mb of ddr 266 ram - Crucial
40 gig Maxtor hdd
Geforce 3 video
Philips Acoustic Edge Sound
I don't have any device errors or conflicts in hardware profile. My ram is in the slot closest to the processor (not sure if that's the "best spot"), and I've tried like all the bios settings differently to try and get it to stop just freezing and it didn't work.
SO WHAT DO I DO?
Unfortunately I don't want to end up spending hundreds of dollars trying to figure the problem out with new components like my friend did.
So what would normally just cause a random system freeze? I can't pinpoint anything similar going on at the times of these freezes.
PLEASE HELP
1 ghz Thunderbird
Asus a7n8x-x
40 gig Maxtor hdd
Geforce 3 video
SO WHAT DO I DO?
PLEASE HELP
