- Apr 15, 2005
- 6
- 0
- 0
Hi, I've encountered a problem recently that's been puzzling to my friend and me. The problem is that my laptop computer randomly shuts down - no, abruptly turns off periodically. It doesn't matter what I'm doing on it - at first, it only turned off while playing games (such as Warcraft III, etc.), but then it started happening even while I was simply browsing the web. It even happened when I was reinstalling windows (after reformatting my hard drive).
I do not get an error message of any kind; my computer simply turns itself off. The frequency of occurrence is also random: sometimes, I can go for hours without having it turn off, but other times it will continuously do it within 5-20 minutes of turning it back on. There is something weird: my system specs say that I have 2 CPU's - I only have one, and this has never happened before the last time I checked. I tried to uninstall the driver from device manager, but it's still there.
The problem started after I installed a faulty patch from Blizzard for Warcraft III; it opened up the command prompt and started doing weird things, and my printer started putting paper through.. perhaps it also caused the double cpu thing?
Also, when running DxDiag, it tells me that the last time I ran Direct3D it encountered an error; it asks if I want to bypass running it and such. Even though I click "no," it happens the next time I run it again. As far as I know, my settings for Direct3D on my Mobility Radeon 9600 are default. I don't know if this may be contributing to the problem, but yeah.
If anyone can help me with this annoying problem, please do! I will be extremely grateful and thank you in advance.
Below are my system specs and a copy of my DxDiag report:
System Information
Time of this report: 5/12/2005, 22:31:01
Machine name: GENESIS
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp1.020828-1920)
Language: English (Regional Setting: English)
System Manufacturer: American Megatrends Inc.
System Model: 258SA5
BIOS: BIOS Date: 02/25/04 17:03:15 Ver: 08.00.09
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 154MB used, 2308MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0 (4.09.0000.0900)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0000.0900 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: The file ALCXWDM.SYS is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: MOBILITY RADEON 9600
Manufacturer: ATI Technologies Inc.
Chip type: MOBILITY RADEON 9600 Series AGP (0x4E50)
DAC type: Internal DAC(350MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E50&SUBSYS_23121584&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6396 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/28/2003 06:54:16, 375808 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 10/28/2003 06:53:50, 619520 bytes
Device Identifier: {D7B71EE2-0D10-11CF-C86E-1803A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E50
SubSys ID: 0x23121584
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1039&DEV_7012&SUBSYS_51041584&REV_A0
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5050 (English)
WHQL Logo'd: No
Date and Size: 4/21/2003 05:00:00, 695852 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 48000
Static/Strm HW Mix Bufs: 17, 16
Static/Strm HW 3D Bufs: 17, 16
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: Modem #0 Line Playback (emulated)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Description: Modem #0 Line Record (emulated)
Default Sound Capture: No
Default Voice Capture: No
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x20
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1039, 0x7001
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/21/2003 05:00:00, 51968 bytes
| Driver: usbd.sys, 4/21/2003 05:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ PC/AT Enhanced PS/2 Keyboard (101/102-Key)
| Matching Device ID: *pnp030b
| Service: i8042prt
| Driver: i8042prt.sys, 4/21/2003 05:00:00, 51072 bytes
| Driver: kbdclass.sys, 4/21/2003 05:00:00, 23424 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 03:46:42, 38024 bytes
+ Synaptics PS/2 Port Pointing Device
| Matching Device ID: *pnp0f13
| Upper Filters: SynTP
| Service: i8042prt
| Driver: mouclass.sys, 4/21/2003 05:00:00, 22016 bytes
| Driver: SynTP.sys, 4/24/2003 01:08:16, 270448 bytes
| Driver: SynTPAPI.dll, 4/24/2003 01:16:22, 94208 bytes
| Driver: SynTPFcs.dll, 4/24/2003 01:50:48, 65536 bytes
| Driver: SynCOM.dll, 4/24/2003 01:18:24, 77824 bytes
| Driver: SynCtrl.dll, 4/24/2003 01:19:06, 110592 bytes
| Driver: SynTPLpr.exe, 4/24/2003 01:51:36, 110592 bytes
| Driver: SynTPCpl.dll, 4/24/2003 01:30:52, 5132288 bytes
| Driver: SynCntxt.rtf, 4/24/2003 01:22:28, 2091745 bytes
| Driver: SynZMetr.exe, 4/24/2003 01:02:24, 159744 bytes
| Driver: SynMood.exe, 4/24/2003 01:01:20, 147456 bytes
| Driver: SynTPEnh.exe, 4/24/2003 01:44:56, 610304 bytes
| Driver: SynTPEnh.ini, 4/24/2003 01:50:34, 7244 bytes
| Driver: SynTPCOM.dll, 4/24/2003 01:22:20, 40960 bytes
| Driver: Tutorial.exe, 4/24/2003 01:52:46, 212992 bytes
| Driver: InstNT.exe, 4/24/2003 01:58:10, 69632 bytes
| Driver: SynISDLL.dll, 4/24/2003 01:54:14, 483328 bytes
| Driver: SynUnst.ini, 4/24/2003 02:03:16, 53548 bytes
| Driver: SynTPCoI.dll, 4/24/2003 01:57:42, 77824 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC01B
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 4/21/2003 05:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Smart Link 56K Modem
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 33.3 GB
Total Space: 38.1 GB
File System: NTFS
Model: HTS548040M9AT00
Drive: E:
Model: Slimtype COMBO LSC-24082K
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 47488 bytes
System Devices
Name: Network Controller
Device ID: PCI\VEN_8086&DEV_4220&SUBSYS_27018086&REV_05\3&267A616A&0&58
Driver: n/a
Name: O2Micro OZ711M1 MemoryCardBus Controller
Device ID: PCI\VEN_1217&DEV_7114&SUBSYS_30051584&REV_20\3&267A616A&0&49
Driver: C:\WINDOWS\System32\DRIVERS\pcmcia.sys, 5.01.2600.1106 (English), 8/29/2002 01:09:12, 115712 bytes
Device ID: PCI\VEN_1217&DEV_7114&SUBSYS_30051584&REV_20\3&267A616A&0&48
Name: O2Micro OZ711Mx MemoryCardBus Accelerator
Device ID: PCI\VEN_1217&DEV_7110&SUBSYS_30051584&REV_00\3&267A616A&0&4A
Driver: C:\WINDOWS\System32\Drivers\o2mmb.sys, 1.00.0006.0000 (English), 8/27/2003 04:02:42, 187668 bytes
Driver: C:\WINDOWS\System32\Drivers\MbxStby.sys, 1.00.0000.0005 (English), 8/25/2003 19:46:00, 5817 bytes
Name: Smart Link 56K Modem
Device ID: PCI\VEN_1039&DEV_7013&SUBSYS_40031584&REV_A0\3&267A616A&0&16
Driver: C:\WINDOWS\System32\Drivers\mtlmnt5.sys, 0.2005.2003.1322 (English), 5/19/2003 22:23:10, 210592 bytes
Driver: C:\WINDOWS\System32\Drivers\mtlstrm.sys, 0.406.2003.1512 (English), 6/4/2003 00:15:12, 1295600 bytes
Driver: C:\WINDOWS\System32\Drivers\slnthal.sys, 0.2005.2003.1318 (English), 5/19/2003 22:19:24, 85688 bytes
Driver: C:\WINDOWS\System32\Drivers\ntmtlfax.sys, 0.1905.2003.1529 (English), 5/19/2003 00:30:02, 169120 bytes
Driver: C:\WINDOWS\System32\Drivers\slntamr.sys, 0.1305.2003.1056 (English), 5/12/2003 19:58:34, 521408 bytes
Driver: C:\WINDOWS\System32\Drivers\slwdmsup.sys, 4.00.0001.0001 (English), 1/16/2003 10:19:32, 39348 bytes
Driver: C:\WINDOWS\slrundll.exe, 1/16/2003 10:47:52, 24576 bytes
Driver: C:\WINDOWS\System32\SLGen.dll, 1/16/2003 11:01:02, 159744 bytes
Driver: C:\WINDOWS\System32\coinst.dll, 1.00.0000.0001 (English), 1/16/2003 11:09:52, 49152 bytes
Driver: C:\WINDOWS\System32\slserv.exe, 1.00.0000.0001 (English), 5/19/2003 22:24:20, 45056 bytes
Driver: C:\WINDOWS\System32\slextspk.dll, 1.00.0000.0001 (English), 1/16/2003 11:10:34, 188416 bytes
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_1039&DEV_7012&SUBSYS_51041584&REV_A0\3&267A616A&0&17
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 4096 bytes
Driver: C:\WINDOWS\System32\ksproxy.ax, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 117248 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/17/2001 15:37:04, 22016 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 130304 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.1106 (English), 8/28/2002 18:32:34, 57856 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1106 (English), 8/28/2002 19:01:00, 134272 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 45696 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.5050 (English), 4/21/2003 05:00:00, 695852 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.00.0000.0016 (English), 4/21/2003 05:00:00, 46592 bytes
Driver: C:\WINDOWS\System32\ALSNDMGR.CPL, 1.05.0000.0063 (English), 4/21/2003 05:00:00, 1607168 bytes
Driver: C:\WINDOWS\System32\ALSNDMGR.WAV, 4/21/2003 05:00:00, 141016 bytes
Driver: C:\WINDOWS\system\crlds3d.dll, 4.12.0001.2002 (English), 4/21/2003 05:00:00, 765952 bytes
Driver: C:\WINDOWS\System32\a3d.dll, 4.12.0001.2008 (English), 4/21/2003 05:00:00, 720896 bytes
Driver: C:\WINDOWS\System32\Audio3D.dll, 4.12.0001.2008 (English), 4/21/2003 05:00:00, 720896 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1039&DEV_7007&SUBSYS_55001584&REV_00\3&267A616A&0&13
Driver: C:\WINDOWS\System32\DRIVERS\ohci1394.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 55680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\1394bus.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 50560 bytes
Driver: C:\WINDOWS\System32\DRIVERS\nic1394.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 57984 bytes
Driver: C:\WINDOWS\System32\DRIVERS\arp1394.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 57344 bytes
Driver: C:\WINDOWS\System32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 06:46:40, 6400 bytes
Name: SiS PCI to USB Enhanced Host Controller
Device ID: PCI\VEN_1039&DEV_7002&SUBSYS_55001584&REV_00\3&267A616A&0&1B
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 19328 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 135552 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 51968 bytes
Driver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 5120 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 15:36:34, 67072 bytes
Name: SiS 7001 PCI to USB Open Host Controller
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_55001584&REV_0F\3&267A616A&0&1A
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.1106 (English), 4/21/2003 05:00:00, 15744 bytes
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_55001584&REV_0F\3&267A616A&0&19
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_55001584&REV_0F\3&267A616A&0&18
Name: SiS PCI IDE UDMA Controller
Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_55131584&REV_00\3&267A616A&0&15
Driver: C:\WINDOWS\System32\DRIVERS\siside.sys, 2.02.0001.0000 (English), 4/21/2003 05:00:00, 5760 bytes
Name: SiS 900-Based PCI Fast Ethernet Adapter
Device ID: PCI\VEN_1039&DEV_0900&SUBSYS_51071584&REV_91\3&267A616A&0&20
Driver: C:\WINDOWS\System32\DRIVERS\sisnic.sys, 1.16.0000.0000 (English), 7/10/2002 08:39:34, 32256 bytes
Driver: C:\Progra~1\SiSLan\uninst.exe, 5.01.2413.0001 (English), 8/6/2001 19:53:18, 37376 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1039&DEV_0648&SUBSYS_00000000&REV_51\3&267A616A&0&00
Driver: n/a
Name: SIS PCI to ISA bridge
Device ID: PCI\VEN_1039&DEV_0008&SUBSYS_00000000&REV_14\3&267A616A&0&10
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 4/21/2003 05:00:00, 35840 bytes
Name: SiS Accelerated Graphics Port
Device ID: PCI\VEN_1039&DEV_0003&SUBSYS_00000000&REV_00\3&267A616A&0&08
Driver: C:\WINDOWS\System32\DRIVERS\SISAGPX.SYS, 7.02.0000.1170 (English), 7/17/2003 18:58:20, 36992 bytes
Name: MOBILITY RADEON 9600
Device ID: PCI\VEN_1002&DEV_4E50&SUBSYS_23121584&REV_00\4&13EB4D69&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\ati2mtag.sys, 6.14.0010.6396 (English), 10/28/2003 06:53:50, 619520 bytes
Driver: C:\WINDOWS\System32\ati2dvag.dll, 6.14.0010.6396 (English), 10/28/2003 06:54:16, 375808 bytes
Driver: C:\WINDOWS\System32\Ati2mdxx.exe, 4.13.0001.0003 (English), 9/4/2001 01:24:26, 28672 bytes
Driver: C:\WINDOWS\System32\ati3d1ag.dll, 6.14.0010.3976 (English), 10/28/2003 06:41:40, 853152 bytes
Driver: C:\WINDOWS\System32\ati3d2ag.dll, 6.14.0010.3976 (English), 10/28/2003 06:45:30, 1039296 bytes
Driver: C:\WINDOWS\System32\ati3duag.dll, 6.14.0010.0200 (English), 10/28/2003 06:50:46, 1164352 bytes
Driver: C:\WINDOWS\System32\ATIDDC.DLL, 6.14.0010.0005 (English), 10/28/2003 06:51:16, 81920 bytes
Driver: C:\WINDOWS\System32\atitvo32.dll, 6.14.0010.4100 (English), 10/28/2003 06:36:42, 17408 bytes
Driver: C:\WINDOWS\System32\ativcoxx.dll, 6.13.0010.0005 (English), 11/8/2001 20:01:04, 24064 bytes
Driver: C:\WINDOWS\System32\ati2evxx.exe, 6.14.0010.4089 (English), 10/28/2003 06:51:56, 376832 bytes
Driver: C:\WINDOWS\System32\ati2evxx.dll, 6.14.0010.4089 (English), 10/28/2003 06:52:02, 86016 bytes
Driver: C:\WINDOWS\System32\atipdlxx.dll, 6.14.0010.2485 (English), 10/28/2003 06:52:18, 110592 bytes
Driver: C:\WINDOWS\System32\Oemdspif.dll, 6.14.0001.0010 (English), 10/28/2003 06:52:12, 102400 bytes
Driver: C:\WINDOWS\System32\ati2edxx.dll, 6.14.0010.2488 (English), 10/28/2003 06:52:06, 34816 bytes
Driver: C:\WINDOWS\System32\atioglxx.dll, 6.14.0010.4012 (English), 10/28/2003 07:13:50, 4595712 bytes
Driver: C:\WINDOWS\System32\atiiiexx.dll, 6.14.0010.3010 (English), 10/28/2003 07:43:32, 229376 bytes
DirectX Components
ddraw.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 284160 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1177600 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1634304 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 436224 bytes
d3dim700.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 4/21/2003 05:00:00 33040 bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 4/21/2003 05:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dpnhupnp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 4/21/2003 05:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 4/21/2003 05:00:00 151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 4/21/2003 05:00:00 168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 394240 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 4/21/2003 05:00:00 65536 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 76800 bytes
pid.dll: 5.01.2600.1106 English Final Retail 4/21/2003 05:00:00 31744 bytes
dsound.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 355328 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 491520 bytes
dmusic.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 116736 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1189888 bytes
dxdiagn.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1675264 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 4/21/2003 05:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 4/21/2003 05:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 4/21/2003 05:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 132096 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 4/21/2003 05:00:00 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 311808 bytes
qdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 449024 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1962496 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 4/21/2003 05:00:00 251904 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324096 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 45696 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 12/4/2002 01:33:40 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:03:54 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:20 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:32 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:24 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 12/4/2002 01:33:42 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 12/4/2002 01:33:22 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 12/6/2002 23:56:36 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 12/6/2002 23:55:36 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:03:54 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 12/4/2002 01:34:46 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:03:56 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:14 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:12 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 12/4/2002 01:33:56 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:20 16896 bytes
kstvtune.ax: 5.03.0000.0900 English Final Retail 12/4/2002 12:07:26 274432 bytes
ksxbar.ax: 5.03.0000.0900 English Final Retail 12/4/2002 01:33:50 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 12/4/2002 12:07:34 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:12 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 12/4/2002 02:04:14 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 11/12/2002 19:15:30 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.00.3312.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0900
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0900
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0900
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0900
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.04.2600.1106
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0900
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0900
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0900
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0900
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.2980
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0900
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0900
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.2980
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0900
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.04.2600.1106
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0900
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0900
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0900
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.00.3312.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0900
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0900
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0900
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.04.2600.1106
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0900
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0900
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0900
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0900
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0900
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0900
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0900
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0900
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0900
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0900
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0900
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.0000.0900
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0900
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0900
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0900
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0900
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0900
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0900
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0900
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0900
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0900
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0900
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0900
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0900
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.0001.0900
Modem #0 Line Record,0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0900
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0900
WDM Streaming Capture Devices:
Realtek AC97 Audio,0x00200000,3,3,,5.03.0000.0900
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1106
XDS Codec,0x00200000,0,0,encdec.dll,6.04.2600.1106
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.0001.0900
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0900
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0900
DirectSound: Modem #0 Line Playback (emulated),0x00200000,1,0,quartz.dll,6.05.0001.0900
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.0001.0900
Modem #0 Line Playback,0x00200000,1,0,quartz.dll,6.05.0001.0900
WDM Streaming System Devices:
Realtek AC97 Audio,0x00200000,16,2,,5.03.0000.0900
System Information
Memory: 1024MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x1002
Device ID: 0x4E50
Revision ID: 0x0000
Revision ID: 0x0000
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: No
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x20
Format Flags: 0x0
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 33.3 GB
File System: NTFS
Drive: E:
System Devices
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
