Recently I put together a new machine...here's what I got goin:
New Parts:
ECS KN1 SLI Lite v1.1d (updated bios)
Zalman NB47J northbridge passive heatsink
AMD Athlon 64 X2 4200+ (w/ Arctic Cooling Freezer Pro 64)
Powercolor x800GTO 256mb
Old parts:
Antec TruePower (Ver 1) 430 watt PSU
three WD hard drives, one Quantum hard drive
3.5" floppy drive
one stick 512mb ddr333 (I unfortunately found that my other 512mb stick DDR266 would not work, in fact it would not boot up the computer)
DVD burner
CD Drive
PCI ata/133 Raid controller card
Tv Tuner card
3 case fans, all connected to a custom made fanbus.
I just put it all together last night, wiped my main HDD clean and put a fresh copy of WindowsXP on it and SP2, and it was running well for a number of hours. However this morning as I was updating a program of mine (FFXI if you must know...), it suddenly restarted. I was away from the pc and the monitor was off so I didn't see what caused the problem, but I heard the hard drives go off. When I went to turn the monitor back on it was already rebooting itself.
Just now as I was setting up the same program, it rebooted again, but this time I saw that I saw the BSOD flash on my screen before rebooting itself.
My question is, is there any known problem of random reboots with my particular motherboard or any of the other components that I listed?
I've also had the computer freeze on me while starting up a couple 3d games. Once in one game, and once in another. I don't know what's causing it as I don't think things are overheating. The mobo bios reports that my CPU is holding at a steady 41-43 C, and my system is at 30-33C. I have no way to tell how hot the northbridge is getting, and one thing about the passive NB heatsink is that it's just ever so slightly kissing the heatsink on my x800GTO. There is a molex power plug right next to the first pci-e slot which I believe is used for SLI configuration, and I figured I would not need it for a single card approach. Do I need to plug that in after all?
New Parts:
Old parts:
3.5" floppy drive
DVD burner
CD Drive
Tv Tuner card
