About 6 months ago I replaced the dead 235w PSU that came with the case I've had for a couple of years with a 250w Enlight PSU. About a month ago my machine started randomly rebooting itself or Win2K would blue screen out. I have a Celery 2 566->850mhz that was running stable at 1.8V and about 45C (48C under a heavy load). My machine will run for days without a problem, but it seem to only be when I'm actually doing something (surfing, games, whatever) that I'll have a problem. Specs are as follows.
Celery 566->850mhz 1.8V
Asus P3V4X BIOS 1006.002
Asus S370 slotket
GlobalWin FOP32-1
128MB PC100-CAS2
V3-2000
2 PCI NIC's
El Cheapo PCI Sound Card (for free what the heck!)
DVD and a burner
15GB IBM GXP75 HDD
30GB WD HDD
A couple of 80mm case fans
I've tried setting my RAM to CAS3 & tried different sticks with the same results, boosting the CPU voltage up to 1.9 (at 850mhz) with the same results. My machine will crack OGR all night at 953mhz and 1.9 core voltage so I think 850 isn't out of the question for stability. Do I need to get a better PSU? 300 Watts good enough? Anything else I should try? I suppose I should try going back to 566 for a bit, but why would it run fine at 850mhz for several months and then start doing this?
Asus S370 slotket
GlobalWin FOP32-1
128MB PC100-CAS2
V3-2000
2 PCI NIC's
DVD and a burner
15GB IBM GXP75 HDD
30GB WD HDD
