Random question: How much does a '96 Nissan Maxima weigh?
LakerGod
2,477
Originally posted by: NutBucket
hell no. more like 3300 lbs. check edmunds.
Crap, that means I can't take advantage of a 39.99 wheel alignment coupon. :brokenheart:
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
A 4-door Geo Metro weighs almost exactly one ton (give or take 14 pounds). It's a safe bet that the Maxima is at least 1.5 tons.
ZV
toant103
10,514
hahaha. you can check by the driver door
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
No, you can't. The sticker lists the load ratings, not the curb weight. GVWR is not the weight of the car. It's the maximum that the car can permissably weigh when fully loaded with passengers and luggage. This can be sometimes 1,000 pounds or more over the car's curb weight.
ZV
LakerGod
2,477
I just checked edmunds.com, it's the curb weight is 3001 lbs. Thanks for the help guys. If anybody wants to suggest a cheap, yet reliable place to get a wheel alignment, let me know. :D
Zee
5,171
take out all your seats, go with a near empty fuel tank and otherwise gut the car. maybe you can make it 1 ton. :D
NutBucket
27,154
635
Coupons and car repair are like oil and water.
Jalapeno
991
10
Mine weighs in at around 6,000+ pounds with all the amps and woofers added! Oh well, it's my neighbour's teenage son's...
Pain in the *middlefinger* butt...
Banned
Feb 17, 2003
1,948
there are maybe a handful of production cars that weigh less than a ton, so i guess not many can take advantage of this coupon.
unless u do mods of ur own and they weigh the car on the spot.
mAdD INDIAN
7,804
The 96 and 95 are the ligghtest.
if you have GXE model it weighs around 3000lbs. Many owners have weighed their modified 95 Maxima and reported under 3000lbs, some are 2900lbs.
Go ask on forums.maxima.org
The SE & GLE trims weigh more due to more equipment.
4th gen Maximas were lighter than their Accord & Camry counterparts. On the other hand, the 3rd gen were quite heavy.
NeoPTLD
2,544
There's only a handful of car that weighs less than 2,000lbs.
Perhaps you misunderstood the definition of one ton here?
A 1 ton pick up, which they consider to be a full pickup means 2,000lbs capacity in the bed.
