Random lock ups on my system, HELP!
Nocturnal
My system is as follows:
Motherboard: ASUS A8N-SLI Deluxe BIOSES: 1008, 1011, 1012-003 beta
CPU: AMD 64 3200+ Winchester
Memory: 2x512MB Crucial Ballistix PC3200
Hard Drive 1: 74GB Western Digital Raptor
Hard Drive 2: 300GB Maxtor Maxline 10
PSU: Antec TrueControl 550W
Video Card: eVGA 6800GT PCI-Express
Case: Antec P160 w/1x120mm intake and 1x120mm exhaust
Plextor 716SA SATA DVDRW
My problem:
Ever since I upgraded my BIOS to 1011 final, then to 1012-003 beta, then down to 1011 final again, then finally down to 1008, I have been experiencing lock ups that freeze my entire computer. No BSODs or errors in event viewer. Just freezes my computer up completely. I cannot even ctrl-alt-del either.
When I first started experiencing these lock ups it was when I upgraded to 1011 final BIOS. It would boot into Windows and as soon as I got maybe ten seconds into Windows it would freeze just like how it?s randomly freezing. Removing one stick of memory seemed to stabilize the system. I then upgraded to 1012-003 beta. From there I encountered problems with my Plextor 716SA SATA burner. So I downgraded to 1011 final again and things seemed ok. However I started to experience the same random lock ups. I downgraded to 1008 and still encountered the same lock up. I am now at 1006 and I am wondering what might be causing this lock up? I?m going to go out on a limb and remove one stick of memory if my system locks up once more.
Do any of you have any other ideas as to what might be happening?
What if it's a BIOS issue? How would I pin point that? Just reflashing until I don't have any issues?
It's very hard to recreate the problem. I can be doing random things such as installing a game to just surfing the web when the computer freezes up.
The only other thing I could think of would be the PSU, but your does seem quite sufficient for the system you've got. 😕
Yeah. It only started happening when I upgraded my BIOS though. I'm currently using 1006 and I did the memtest86 thing over night. While I'm gone I'm going to run Prime95 torture test to see if I can get it to recreate the problem. Otherwise if it doesn't happen I'm going to have to chalk it up to the culprit being my BIOS.
