- Jan 31, 2006
- 4,118
- 34
- 91
I'm writing this post for those of us who have those random freezes, lock ups and reboots.
DISCLAIMER: This post does not hold the absolute truth and the ultimate method to solve this issue. It is a compilation of things I have done on my computer that helped me understand and correct (for now) this issue. *crosses fingers*
With that said, here are the steps I took on from the first day those lock ups occured.
1- My current RIG was updated decembre 2005 (see sig.). It was running rock solid and was very stable until the 1st week of march. My computer started acting weird. Freezes and reboots were happening at random times. On a cold start, all was running ok and then, 5 minutes, 5 hours or 1 day later, the problem happened again. That's when I started to check these forums for answers.
2- I read some posts talking about faulty power supplies. Mine was an old and dated 350W. After some reading, I decided it could be the problem with my freezes so I bought a new OCZ 450W PSU. After only 1 day of playing and other things, it happened again.
3- Right after that, I decided I'd format my computer and try it under a fresh WinXP
install. That I did and updated all the drivers (VIA, Ethernet, Graphic card, Sound,
Windows updates, etc). After only 2-3 hours later, BOOM! Happened again.
4- Then, I moved my hardware in the computer case to let the air circulate easier and i've cleaned the case from dust and other things.
5- I came back to these forums and found another clue. One guy had found that some driver version of the motherboard integrated LAN was causing computer instabilities.
The Marvell Yukon driver 7.xx.x.x (x= I don't recall which version) was faulty and the new version 8.49.3.2 were supposedly stable. I installed them and so far so good.
6- I found that my video card was on the same IRQ than my sound card. Many of you don't think it as a problem but some mentionned that in rare cases, it can cause some lock ups. So I placed my sound card on another PCI slot not shared with the AGP slot. So far so good.
7- Another guy was talking about issues caused by having Legacy USB enabled in the BIOS, which is by default. I disabled it. So far so good.
8- I checked my temps and everything seems to be normal.
CPU idle: 35-37 degrees
CPU full throttle: 37-42 degrees
Video card idle: 57-58 degrees
Video card full throttle: 62-65 degrees
Motherboard: 27-32 degrees (approximately)
Ambient temp: 30 degrees (average, if I recall correctly)
So for now, it's been 3 days and everything is running smoothly. I know it's too soon to
be sure everything is flawless, but I just wanted to share this with you just in case it could help someone.
