- Feb 23, 2005
- 3,100
- 149
- 116
With GM's new Volt getting a $40,000 price tag slapped on it, it seems less likely that I will ever get to own an electric car. I think the problem is we are trying to make a silver bullet but the technology is not available yet (or not affordable). I came up with a random idea that has pretty much been done already, but never marketed, that would be a good stop gap until we get more cost effective technology out. I'm sure it's full of holes since I'm just applying my basic knowledge of electricity and such to it, so I'm just throwing the idea out there to see if it has any merit.
Take a small light car like the Mini or your favorite Toyota, rip out the large engine and replace it with a small (around 1L) Gas/diesel engine to power a generator, wire the generator to some large capacitors that will store enough power to feed the electric motor if you floor the accelerator pedal while the gas engine revs up to deliver more RPMs to the generator to keep power up and then have either a standard electric motor or those new in wheel motors drive the car. The capacitors will be lighter than batteries and cheaper, the trade off is you you are still burring gas to power the car but less of it (unless I'm wrong and just came up with a more complicated way to burn gas).
So basically:
Small gas egine spins generator to make electricity ---> electricity is sent to a small bank of capacitors to keep enough power stored to smooth out the flow of electricity ----> electricity is then sent to electric motor -----> electric motor is conected to the transmission and powers the wheels.
I'm betting that would get high enough MPG to attract buyers, give good 0-60 times, be cheap enough to build that it could be sold for well under $30k (depending on the frame it's built on) and get people turned onto the idea of electric cars while we figure out how to make a full electric car that everyone can afford.
So, does this idea sink or float?
So basically:
