Hello.
Over the last month or so there has been constant trouble with network connections on my friends computer. The general symptoms are about 5% packet loss when pinging both outside locations and internal addresses. There seems to be no pattern to the failure. To rule out the network and isolate the problem to his computer i connected a different computer to his location on the network and verified that the network worked perfectly. I also booted a Gentoo live cd on his computer (on his location in the network) and the ping results showed zero lost packets over about 450 trials. After a clean install of XP(SP2) the random ping time outs still existed. To further verify this as a xp configuration problem i added a second nic (was origially using the onboard) and the problem still existed.
here are the system specs:
Albatron KX600 Pro
Athlon XP 2200+
Linksys LNE100TX (pci)
3Com 3C910 (integrated)
here is some of the output from a ping:
Reply from 192.168.0.1: bytes=32 time<1ms TTL=64
Request timed out.
Request timed out.
Ping statistics for 192.168.0.1:
Packets: Sent = 1197, Received = 1126, Lost = 71 (5% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
as you can see above 71 were lost out of 1197 some of these were grouped quite close and some spread far apart. If anyone could suggest a course of action to fix this problem please let me know, thanks in advance.
[first post!] -nomura
Albatron KX600 Pro
Athlon XP 2200+
Request timed out.
Request timed out.
