System Information
Time of this report: 3/15/2006, 13:38:47
Machine name: BIGJELLY
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: GBT___
System Model: AWRDACPI
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 281MB used, 2182MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: All tests were successful.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9600 PRO
Manufacturer: ATI Technologies Inc.
Chip type: Radeon 9600 Pro
DAC type: Internal DAC(500MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4150&SUBSYS_00021002&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 960 (32 bit) (60Hz)
Monitor: BENQ FP767
Monitor Max Res: 1280,1024
Driver Name: ati2dvag.dll
Driver Version: 6.14.0001.6307 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/20/2003 10:23:04, 272512 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 3/20/2003 10:22:38, 576896 bytes
Device Identifier: {D7B71EE2-0210-11CF-116B-0320A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4150
SubSys ID: 0x00021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC1,0x31434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,0x31434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC2,0x32434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,0x32434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC3,0x33434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,0x33434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(IMC4,0x34434d49) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,0x34434d49) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(S340,0x30343353) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,0x30343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(S342,0x32343353) Frames(Prev/Fwd/Back)=(0,0,1) Caps=DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,0x32343353) Frames(Prev/Fwd/Back)=(0,0,0) Caps=DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: SB Audigy Audio [A000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_10071102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0383 (English)
WHQL Logo'd: Yes
Date and Size: 4/10/2003 23:32:36, 502160 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: All tests were successful.
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy DirectMusic Synthesizer [A000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy Audio [A000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Synth B [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Sw Synth [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Synth A [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy MIDI Port [A000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy MIDI Port [A000] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 01:08:42, 57600 bytes
| Driver: usbd.sys, 8/23/2001 06:00:00, 4736 bytes
Gameport Devices
+ Intel(R) 82801 PCI Bridge - 244E
| Matching Device ID: pci\ven_8086&dev_244e
| Service: pci
| Driver: pci.sys, 8/4/2004 01:07:46, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00601102
| | Service: ctgame
| | Driver: ctgame.sys, 12/29/2002 22:53:36, 12160 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 00:14:36, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 23:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 02:01:07, 40840 bytes
+ Microsoft USB IntelliMouse Optical
| Vendor/Product ID: 0x045E, 0x0039
| Matching Device ID: hid\vid_045e&pid_0039
| Service: mouhid
| Driver: mouclass.sys, 8/3/2004 23:58:32, 23040 bytes
| Driver: mouhid.sys, 8/23/2001 06:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: All tests were successful.
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 19.3 GB
Total Space: 39.2 GB
File System: NTFS
Model: IBM-DTLA-305040
Drive: D:
Free Space: 1.1 GB
Total Space: 76.3 GB
File System: NTFS
Model: WDC WD800BB-00CAA1
Drive: E:
Free Space: 90.7 GB
Total Space: 238.5 GB
File System: NTFS
Model: WDC WD2500JD-00HBC0
Drive: F:
Model: LITE-ON DVDRW SOHW-1633S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 23:59:52, 49536 bytes
Drive: G:
Model: SAMSUNG DVD-ROM SD-816B
System Devices
Name: Intel(R) 82875P Processor to AGP Controller - 2579
Device ID: PCI\VEN_8086&DEV_2579&SUBSYS_00000000&REV_02\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/4/2004 01:07:42, 42368 bytes
Name: Intel(R) 82875P/E7210 Memory Controller Hub - 2578
Device ID: PCI\VEN_8086&DEV_2578&SUBSYS_00000000&REV_02\3&13C0B0C5&0&00
Driver: n/a
Name: Intel(R) 82801ER SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_24DF&SUBSYS_24DF1458&REV_02\3&13C0B0C5&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\iaStor.sys, 3.00.0000.2344 (English), 3/21/2003 00:00:00, 201088 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_24D21458&REV_02\3&13C0B0C5&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:38, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:42, 57600 bytes
Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_50061458&REV_02\3&13C0B0C5&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 01:56:42, 7168 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_24D21458&REV_02\3&13C0B0C5&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:42, 95360 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_24D21458&REV_02\3&13C0B0C5&0&EA
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_24D21458&REV_02\3&13C0B0C5&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_24D21458&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_24D21458&REV_02\3&13C0B0C5&0&E8
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&13C0B0C5&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:46, 68224 bytes
Name: Intel(R) PRO/100 VE Network Connection
Device ID: PCI\VEN_8086&DEV_1050&SUBSYS_30131458&REV_02\4&1F7DBC9F&0&40F0
Driver: C:\WINDOWS\system32\DRIVERS\e100b325.sys, 7.00.0026.0000 (English), 3/3/2003 21:56:26, 145408 bytes
Driver: C:\WINDOWS\system32\Prounstl.exe, 7.00.0005.0000 (English), 3/3/2003 01:26:52, 118784 bytes
Driver: C:\WINDOWS\system32\e100b325.din, 6/26/2002 15:53:38, 5110 bytes
Driver: C:\WINDOWS\system32\IntelNic.dll, 2.04.0000.0000 (English), 12/28/2002 14:00:02, 24064 bytes
Driver: C:\WINDOWS\system32\e100bmsg.dll, 2/2/2003 15:26:18, 12288 bytes
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00601102&REV_04\4&1F7DBC9F&0&09F0
Driver: C:\WINDOWS\system32\DRIVERS\ctgame.sys, 5.12.0002.0100 (English), 12/29/2002 22:53:36, 12160 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&1F7DBC9F&0&0AF0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 00:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:58:29, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:58:29, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 07:46:40, 6400 bytes
Name: Creative SB Audigy
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_10071102&REV_04\4&1F7DBC9F&0&08F0
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 01:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 01:56:57, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 00:15:21, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 00:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 00:15:49, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 00:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 01:56:57, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0381 (English), 3/25/2003 06:11:24, 134656 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0383 (English), 4/10/2003 23:32:36, 502160 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0381 (English), 3/25/2003 06:12:54, 190176 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0381 (English), 3/25/2003 06:13:02, 6144 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0381 (English), 3/25/2003 06:13:20, 135696 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0381 (English), 3/25/2003 06:13:30, 144736 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0382 (English), 4/2/2003 20:59:46, 850880 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.0383 (English), 4/1/2003 06:07:58, 142752 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0003 (English), 3/13/2003 05:10:36, 15840 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 3/25/2003 06:37:36, 200089 bytes
Driver: C:\WINDOWS\system32\ctstatic.dat, 3/25/2003 06:27:02, 270745 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 3/25/2003 06:22:54, 53674 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 3/25/2003 06:05:34, 65536 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.0381 (English), 3/25/2003 06:19:06, 114688 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.0382 (English), 4/11/2003 03:50:26, 446464 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.0382 (English), 4/11/2003 03:52:18, 598016 bytes
Driver: C:\WINDOWS\system32\default.ecw, 9/22/1999 11:18:50, 2259067 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 02:35:46, 36864 bytes
Driver: C:\WINDOWS\system32\ctbas2w.dat, 3/25/2003 06:37:32, 139067 bytes
Driver: C:\WINDOWS\system32\ctsbas2w.dat, 3/25/2003 06:37:30, 250284 bytes
Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 00:42:28, 7406 bytes
Driver: C:\WINDOWS\system32\Audigy.bmp, 11/12/2001 21:48:20, 1912 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0000.0002 (English), 3/25/2003 05:14:30, 49152 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0351 (English), 3/26/2003 22:58:56, 287920 bytes
Name: Multimedia Controller
Device ID: PCI\VEN_109E&DEV_0878&SUBSYS_6606107D&REV_11\4&1F7DBC9F&0&21F0
Driver: n/a
Name: Multimedia Video Controller
Device ID: PCI\VEN_109E&DEV_036E&SUBSYS_6606107D&REV_11\4&1F7DBC9F&0&20F0
Driver: n/a
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_00000000&REV_00\4&1F7DBC9F&0&50F0
Name: RADEON 9600 PRO - Secondary
Device ID: PCI\VEN_1002&DEV_4170&SUBSYS_00031002&REV_00\4&B7EB302&0&0108
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0001.6307 (English), 3/20/2003 10:22:38, 576896 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0001.6307 (English), 3/20/2003 10:23:04, 272512 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 4.13.0001.0003 (English), 9/4/2001 15:24:26, 28672 bytes
Driver: C:\WINDOWS\system32\ati3d1ag.dll, 6.14.0010.3699 (English), 3/20/2003 09:57:14, 951227 bytes
Driver: C:\WINDOWS\system32\ati3d2ag.dll, 6.14.0010.3699 (English), 3/20/2003 10:06:34, 1153435 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0154 (English), 3/20/2003 10:15:54, 716116 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 5.13.0001.0003 (English), 3/20/2003 10:16:32, 49152 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0001.3002 (English), 3/20/2003 09:42:34, 32768 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 10:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0001.4067 (English), 3/20/2003 10:17:04, 184408 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0001.2478 (English), 3/20/2003 10:17:14, 77824 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0008 (English), 3/20/2003 10:17:10, 73728 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.3604 (English), 3/20/2003 11:01:38, 4636752 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.3004 (English), 1/7/2003 10:47:52, 290816 bytes
Device ID: PCI\VEN_1002&DEV_4150&SUBSYS_00021002&REV_00\4&B7EB302&0&0008
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 06:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 06:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 00:08:21 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 9/1/2005 05:09:39 1224704 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 06:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 01:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 01:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 01:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 20480 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 8/11/2004 00:45:04 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:24 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 21:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 01:56:45 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 01:56:57 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 01:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 01:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 01:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 01:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 01:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 01:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 01:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:15:21 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:41 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:38 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:12 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:57 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:44 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:57 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:57 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:12 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:12 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:12 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:56:43 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:16 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:28 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:16 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:57 90624 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:21 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:46 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:09:58 51328 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.01.0001.1031
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.02.0006.0000
ffdshow MPEG-4 Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0000.0001
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,1.02.0001.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
ATI MPEG Audio Decoder,0x00200000,1,1,atidvcr.dll,8.01.0000.30120
CoreVorbis Audio Decoder,0x00800000,1,1,CoreVorbis.ax,1.00.0000.0002
Matroska Source,0x00600000,0,0,MatroskaSplitter.ax,1.00.0002.0004
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0000.0001
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0018
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0000.0001
CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.ax,5.00.0000.1031
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,1.02.0012.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0018
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,1.01.0001.0000
DV Scenes,0x00200000,1,1,NVDV.dll,2.01.0002.0009
Matroska Splitter,0x00600000,1,1,MatroskaSplitter.ax,1.00.0002.0004
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,1.00.0006.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0000.0009
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CT Null Render Filter,0x00200000,1,0,NullRndr.ax,1.00.0001.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.00.0000.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,NeResize.ax,3.02.0000.0018
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg Audio Encoder,0x00200000,1,1,NeAudioEnc.ax,1.00.0000.0004
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0000.0001
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
ATI Time Shift Splitter,0x00600000,1,3,atidvcr.dll,8.01.0000.30120
ATI Time Shift Reader,0x00600000,0,1,atidvcr.dll,8.01.0000.30120
ATI Time Shift Writer,0x00200000,1,0,atidvcr.dll,8.01.0000.30120
ATI MPEG Video Decoder,0x00600000,1,1,atidvcr.dll,8.01.0000.30120
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,5.00.0000.1028
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
ATI Video Capture Surface Allocator,0x003fffff,1,0,ativvpxx.ax,4.13.0001.5085
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0018
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0018
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0018
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0018
Nero Digital AVC Video Enc,0x00200000,1,2,,
WMS Filter,0x00400000,0,1,CTWMSFLT.DLL,1.12.0001.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0018
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.3030
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0018
ATI VBI Surface Allocator,0x00600000,1,0,AVBISurf.ax,8.00.0000.0001
ATI Video Format Converter,0x00200000,1,1,atidvcr.dll,8.01.0000.30120
Slide Video to MPEG1,0x00000000,0,0,,
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
CoreFLAC Audio Source,0x00600000,0,0,CoreFLACDecoder.ax,0.04.0000.0046
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0018
ATI Line21 CC Decoder/Renderer,0x00200000,1,0,aticcap.ax,8.00.0000.0001
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.1031
Haali Media Splitter,0x00600001,0,1,splitter.ax,
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0018
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980
CyberLink Video/SP Decoder (ATI),0x00600000,2,3,CLVsd.ax,3.05.0000.2524
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0018
CoreFLAC Audio Decoder,0x00600000,1,1,CoreFLACDecoder.ax,0.04.0000.0046
DV Source Filter,0x00400000,0,1,NVDV.dll,2.01.0002.0009
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0018
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,1.01.0000.0000
Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980
ATI Capture Transform Filter,0x00200000,1,3,ativxfxx.ax,6.14.0001.6180
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ATI MPEG Audio Encoder,0x00200000,1,1,atidvcr.dll,8.01.0000.30120
ATI Teletext Provider,0x00600000,1,0,ativtpxx.ax,7.06.0000.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.01.0000.0642
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0018
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Ogg Source,0x00600001,0,0,oggsplitter.ax,1.00.0000.0000
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
ATI MPEG Video Encoder,0x00200000,1,1,atidvcr.dll,8.01.0000.30120
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0000.0009
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0018
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,1.01.0000.0000
LEAD MCMP/MJPEG Codec,0x00100000,1,1,LCODCCMP.DLL,1.00.0000.0016
LEAD MCMP/MJPEG Decoder,0x00800000,1,1,LCODCCMP.DLL,1.00.0000.0016
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0018
ATI MPEG Multiplexer,0x00200000,3,1,atidvcr.dll,8.01.0000.30120
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
ATI Audio Delay Filter,0x00200000,1,1,atidvcr.dll,8.01.0000.30120
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0018
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,1.02.0001.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
ATI Teletext to CC Converter,0x00600000,1,2,atitt2cc.ax,8.00.0000.0002
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
RadLight MPC DirectShow Filter,0x00600000,0,1,RLMPCDec.ax,1.00.0000.0003
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0018
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.00.0000.0009
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0000.0009
ATI MPEG Archiver,0x00200000,0,0,atidvcr.dll,8.01.0000.30120
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.00.0000.0009
ffdshow VFW decoder helper,0x00200000,2,1,ffdshow.ax,1.00.0000.0001
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink Audio Decoder,0x00601000,1,1,claud.ax,5.00.0000.1029
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,5.00.0000.1031
CyberLink TimeStretch Filter,0x00200000,1,1,CLAuTS.ax,1.00.0000.0704
ATI Closed Caption Database,0x00200000,1,0,aticcdb.ax,8.00.0000.0004
Ogg Splitter,0x00600001,1,1,oggsplitter.ax,1.00.0000.0000
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,MP3SRCSP.AX,1.00.0000.0000
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0018
AC3Filter,0x40000000,1,1,ac3filter.cpl,1.00.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0018
ATI Still Capture,0x00200000,1,0,atistill.ax,8.00.0000.0004
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,CTMP3SFT.DLL,1.00.0010.0000
DTS/AC3 Source,0x00400000,0,1,dtsac3source.ax,1.00.0000.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Noise Reduction,0x00100000,1,1,NoisRedu.ax,2.00.0000.0001
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ATI Noise Reduction Filter,0x00200000,1,1,atidvcr.dll,8.01.0000.30120
CyberLink DVD Navigator (ATI),0x00600000,0,3,CLNav.ax,3.05.0000.2406
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0018
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0018
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,1.02.0001.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
ATI Audio Pitch Correction Filter,0x00200000,1,1,atidvcr.dll,8.01.0000.30120
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,1.00.0007.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0018
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0018
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0018
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0018
NVF Filter,0x00400000,0,1,CTNVFFLT.DLL,1.00.0000.0000
Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0018
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0018
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0000.0009
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
LEAD Video Color Filter,0x00000000,0,0,,
LEAD Still Image Reader,0x00200000,0,1,LTStlImgRd.dll,1.00.0000.0006
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,1.02.0008.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0018
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
CyberLink Audio Decoder (ATI),0x00601000,1,1,CLAud.ax,3.05.0000.2417
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0018
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0000.0001
HPOD RunTimeline Filter,0x00000000,0,0,,
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0018
Nero Digital Video Encoder,0x00200000,1,2,,
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 5.1.1 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
ATI YUV12 Format Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video Raw R1.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
Nero Audio Encoder,0x00200000,1,1,NeAudioEnc.ax,1.00.0000.0004
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB Audigy Audio [A000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy MIDI Port [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Sw Synth [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Synth A [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Synth B [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
SB Audigy MIDI Port [A000],0x00200000,2,2,,5.03.2600.2180
SB Audigy Audio [A000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy DirectMusic Synthesizer [A000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Sw Synth [A000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth A [A000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth B [A000],0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
Audio Renderers:
SB Audigy Audio [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,5.00.0000.1006
CyberLink Audio Renderer (ATI),0x00200000,1,0,CLAdr.ax,3.05.0000.2417
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB Audigy Audio [A000],0x00200000,1,0,quartz.dll,6.05.2600.2749
LTMM Video Processors:
WDM Streaming System Devices:
SB Audigy Synth A [A000],0x00200000,11,2,,5.03.2600.2180
SB Audigy Audio [A000],0x00200000,13,2,,5.03.2600.2180
