UPDATED 4/14/11 12:07 PM
Resolution:
1.) Fixing why the computer would freeze: Apparently this was due to the qpi and dram voltage differential. I have to keep the voltages under a 0.45ish Volt difference.
2.) Fixing the BSOD problem: For some reason Zone Alarm caused my BSOD's. Even after reinstalling it, it caused problems. So no more ZA for me.
Problems: (Chronologically sorted)
• I have received various blue screens running windows 7 x64 bit with code 7f and had various random freezes during operation that did not result in a blue screen.
• Sometimes when freezes occured, my speakers would scream at me until powered off.
• Sometimes when freezes occured, my keyboard and mouse lost power.
• It would crash or freeze whether watching a video, playing a game, surfing the web, or doing absolutely nothing.
• One time it crashed and either the motherboard speaker or the video card speaker blared until the computer was shut off.
• It crashed twice when trying to install a fresh copy of windows 7 from cd.
• After the crash, BIOS runs very slow after post.
• My DVD-RW drive that is connected via PATA started giving me could not access errors in windows and slowed my system down whenever it had a cd. It eventually stopped working all together. The Eject button wouldn't respond nor would the led come on. I disconnected it because it was no longer working. Then I decided to give it another try and plugged it back in. Oddly it worked perfectly with no problems.
• I tried to boot my computer once and it didn't post. It gave me this beep sequence once: 1 long then 3 short beeps. I reseated the Video Card then the RAM and it wouldn't even post; the RAM led would light and and nothing else happened. Then I reseated the RAM again and it booted like nothing happened.
• Still had more crashes here is the blue screen code: 0x0000007f (0x0000000000000008, 0x0000000080050031, 0x00000000000006f8, 0xfffff80002e46eb8).
• During a game of MW2: The monitor shut off, sound stopped, and computer appeared to be frozen. I restarted the computer and it worked...
• Still more BSOD's
Troubleshooting:
• Running Memory at 800Mhz and 1.5V with 9-9-9-24 timings (still crashed)
• 5-6 Hours of MemTest86 (No Errors)
• 12 Hours of Prime95 (No Errors)
• 2 Hours of GPU Stress Test (No Errors)
• Monitoring CPU and Motherboard temperatures
• Assuring that there is no overclocking
• Reinstalling the operating system
• Remounting all devices: RAM, CPU, Graphics Card
• Updated BIOS
• RMA'ing the motherboard
• Checked to see if Windows Update (KB973879) was installed (it wasn't)
• Tested each stick of ram individually and received a crash on one and the comp froze then restarted and had a blue screen using the other.
• I ran WhoCrashed to see if anything came up for the problems I'm having. Zone Alarm and Avast were determined culprits. I uninstalled them and things appear to be working fine now.
My System Information:
• P7P55D-E Pro Motherboard
• Intel i7 860 CPU
• 2x2 GB Kingston KHX1600C9AD3K2 DDR3 RAM
• NVIDIA 8800 GTS 640MB Graphics Card
• 3 SATA Hard Drives, 2 of which in Raid 0
• 1 DVD-RW Drive via PATA
• 5 Fans (including cpu fan) every fan connection on the board is used
• PC Power and Cooling S75QB 750W PSU
• 3 connected USB Devices to USB 2.0
• Windows 7 64bit
Resolution:
Resolution:
• Still more BSOD's
Troubleshooting:
• Updated BIOS
• Intel i7 860 CPU
• Windows 7 64bit
Resolution:
