Ran out of contact solution: sleep with them or use some old ass solution?
AznAnarchy99
14,695
117
I forgot to buy some contact solution today. Should I sleep with them in or use some old solution that was used before?
Im leaning towards sleep.
duragezic
11,234
4
Old solution? You mean day old stuff you didn't empty out today? I'd probably just use that. Or go to 24 hour store like Walmart and buy some.
It'd be fine to sleep too. I've done that a number of times but generally don't anymore. One of my friends did it pretty much constantly which I thought was odd but he never had issues.
kyzen
1,557
www.chrispiekarz.com
Just sleep with them in, it's not the end of the world every now and then. worst case scenario, you'll wake up and they'll feel kind of stiff & rubbery; just grab some solution on your way to work/school/whatever and rinse the contacts off.
Also, i can't say enough good things about Bausch & Lomb's PureVision contacts. I leave them in overnight all the time when I can't make it home, or ran out of solution, or am just generally too lazy to take em out.
http://www.bausch.com/en_US/consumer/visioncare/product/softcontacts/purevision_lenses.aspx
AznAnarchy99
14,695
117
No, more like I dont know how long its been there.
chusteczka
3,399
I think it depends on the strength of your prescription. My prescription is at -5.5, -7.0; which is fairly strong and the contacts are thicker. I am not able to sleep with my contacts in and would do everything in my power to visit a 24 hour store to obtain the necessary solution.
As a worst case scenario, you may be able to try water. Boiled but cold water would be best. Your contacts will feel dry when you put them back in your eyes in the morning but you will sleep better.
If you sleep with them in, make sure to add drops to moisten your eyes in the morning before you take them out. The contacts will stick to your cornea and may tear your cornea as you peel them off.
Oct 20, 2005
10,978
44
Just use your old solution.
Tomorrow, go buy some new solution and clean out your contacts before you put them in.
mesthead21
2,378
I put them in water if i don't have solution. Prob not the best idea, but my eyes dry out if i sleep with my contacts in
coldmeat
9,234
142
I sleep with mine in every now and then. Usually cause I'm drunk and don't get around to taking them out before going to bed.
Born2bwire
9,840
Hmmm... if I have no solution whatsoever I just use water. They'll sting when you put them back in but other than that I never had a problem.
jlee
48,518
223
Solution has an expiration date, check it out.
This.
Sleeping with my old contacts (CooperVision 12hr wear) was bad..even if I took a 30min nap with them in, they dried out and felt terrible. I have Acuvue Oasys now, and I can sleep with them in all night (per eye doc).
AeroEngy
356
I will never sleep in contacts again. I used to do it occasionaly when I was in college. Well after finals week and leaving them in to long I developed a corneal ulcer. When I finally took my contacts out it felt like someone was stabbing me in the eye with a needle. It hurt so bad I had to go to the emergency room.
brainhulk
9,376
454
it might ruin them a little because contacts are hydrophillic and will soak up hypotonic water and make them expand. if you are too lazy to go to 24h walgreen, cvs, or riteaid then:
1/4 tsp table salt
8 oz boiled water
this will make a normal saline solution that will not be drawn in to the contacts.
Arcadio
5,637
24
