Rampage V Extreme
amerifax
I have 1 Raid0 on ports 2&3. I have two WD Blacks 1T each on ports 5&6. The WD's do not show up in the Intel Raid setup.
Also concerning is the WD's that are connected to 5&6 show up in the Storage con fig, BIOS, as being on ports 7&8 even thou they are connected to 5&6. This is how they show in the Advanced\Storage Config:
SATA6G_7
SATA6G_8
Bob
SATA6G_7
SATA6G_8
Bob
Bob, did you install the raid driver for the OS? What OS are you using?
I used the drivers from the MB disk and had a heck of a time finding the correct one but finally did. Had to have the DVD as the boot drive. Next make sure you have the WD drivers in the first 2 ports. Finally besure the raid is set in the storage setup in the BIOS AND the CSM setup is set for legacy only in the storage line.
