- Feb 26, 2013
- 30
- 0
- 0
I've been searching for the last few days and haven't found a definitive answer. The question is all about RAM timings and basically is the more aggressive timings worth the price difference and will I (or the average user) see a difference in real world gaming & app / program usage?
The computer in question is a Toshiba L855D-S5114 Laptop
Specs:
AMD A8-4500M @ 1.9ghz (2.8ghz Boost)
AMD 7640G APU
4gb 1600 Single Channel
640gb 5400rpm SATA HDD
The rest I know is insignificant
I purchased the laptop for $379.99 from Best Buy which I think is a great deal for an A8. The problem is the RAM. I've done a lot of research that says that APU's more than anything benefit from faster RAM speeds and Dual Channel. I gathered a couple Dual Channel kits but again, the question arose in my mind, does the RAM Timing increase performance as much as the RAM Speed?
(All listings are 2x4gb Dual Channel Kits @ 1600mhz)
Mushkin Enhanced 11-11-11-28 $47.99
G.Skill 9-9-9-28 $51.99
Corsair Vengeance 9-9-9-24 $56.99
Is the increase in price equal to the increase in performance? Are RAM Timings that important for increasing APU performance?
Specs:
AMD 7640G APU
