Hi guys,
I've been running out of RAM while gaming (and consistently running close to max capacity) so I would like to upgrade my desktop to improve performance. I would also like to be able to alt-tab between programmes (e.g. Teamspeak and my game) more fluently if possible.
My current specs (running Win 7)
According to ASUS, my MB supports the up to 16GB of the following:
2 x DIMM, Max. 16GB, DDR3 1866(O.C.)/1600(O.C.)/1333/1066 MHz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
I'm thinking of taking two 4GB sticks of this RAM :
http://www.kingston.com/us/hyperx/memory/fury
FURY Memory Blue - 8GB Module - DDR3 1333MHz CL9 DIMM
Part Number: HX313C9F/8
Specs: DDR3, 1333MHz, CL9, 1.5V, Unbuffered, Spec Sheet PDF
Timings: 1333MHz, 9-9-9, 1.5V
Is this the best I can do? Is there any advantage to looking at 1600Mhz RAM for me? I read elsewhere on this site that the difference between the two speeds is not noticeable in performance anyway
Is 8GB a good pick?
Crucial memory scanner says 8GB is my maximum RAM - but ASUS product page states 16BG is the maximum capacity. Not sure Ill use more then 8GB anyway.
All insights appreciated!
- CPU AMD Phenom II X4 965
RAM 4GB Kingston ValueRAM DDR3-1333 PC10600 (KVR1333D3N9/4G)
Motherboard ASUSTeK Computer INC. M5A78L-M LX V2 (AM3R2)
Graphics 2048MB ATI AMD Radeon HD 7800 Series (also Asus)
PSU FSP Raider 550 watt (80plus bronze, 450 watt output)
Hard Drives
465GB Seagate ST500DM002-1BD142 ATA Device (SATA)
465GB Western Digital WDC WD5000AAKX-003CA0 ATA Device (SATA)
The case/cooling is nothing special
Is 8GB a good pick?
