Originally posted by: Luckyboy1
Depends on the total case cooling of course, but to begin with, you did pick the right ramsinks, but not the right way of applying them.
Use a mix of 75% artic silver and 25% artic silver epoxy compound. Use some nail polish remover to rid yourself of the sticky garbage that comes stock.
Yes, it would make it so you can clock the video RAM farther if you whipped some air on it. In another thread, they ask what's in your PCI slots. I've got an Audigy 2ZS in the last slot. Then I have a 120 mm Panaflo fan on each side of the video card with a 5 ohm, ceramic resistor to slow the speed of the fans.
Nothing wrong with it and I'm asking you to use 25% of your mix for that. Use any more in the mix and you risk marrying the heatsink to the card forever. You'd feel kinda dumb at that point come rMA time if ever, that's all.
Ok, thanks. Because their website says to use 1:1 mix of it, but I guess if you don't want it on their forever 😉
Also, it's ok to use Artic SILVER on the ram right? Cause I got some Alumina Adhesive, as well as some Artic Silver Adhesive.
You shouldn't mix the two.
I ment mix the two tubes that come with the Artic Alumina Adhesive. See?
So, your saying I can/should use this?
Oh ooops. My mistake. 😱
I would go with the Alumina. But I don't know if you can mix the regular Alumina with the adhesive to weaken the bond so it's not there permanently. I know you can mix the regular Arctic Silver and the adhesive though.
The Alumina Adhesive comes with 2 tubs. Your suppose to mix them together so that in 5 minutes it harderns or somthing to that affect.
So, I should still max it 75/25
Building a water cooling setup, and I already have all the stuff I need (including all 16 OCZ copper ram sinks with Alumina Adhesive to put them on), but I'm just wondering, do you need any airflow over the video cards with the ram sinks? Like with a fan?
Originally posted by: Seer
He's saying Part A and Part B will be 12.5% of the mix EACH (for a total of 25%), then add 75 % AS5.
Originally posted by: peleejosh
AS5 is not conductive
http://www.xtremesystems.org/forums/showthread.php?t=90518&highlight=arctic
