azntiger0586
i am currently using a 5:4 ratio at 250 fsb for my 2.4 (oc to 3.0) and ddr400 ram.
using ddr400 corsairs valueselect (2x256) in dual channel.
my ram is currently running at 7-3-3-2.5
i want to overclock it to 5-3-3-2 (or somewhere close around that)
1) what should i do first? change the cas to 2? or lower the tRAS slowly to 5?
2) How would i know that my vdimm would need a bump in the voltage?
3) What errors can i expect when running the computer normally?
4) After everything seems stable, how long should memtest be run until the rams are consider "stable"
PS: Would heat be increased greatly? and how good are heat spreaders?
Many Thanks.
Many Thanks.
