RAM Problems!
viper007
Banned
Aug 25, 2000
202
Hey there groovy forum people! heh
I have been trying to make a friends system a little more usable and upgrade his memory from 16mb. He has a piece of rubbish IBM Aptiva P166.. He currently has 2x8mb simms, and I don't know wether they are FPM or EDO. Anyway when I try to install 2x 16mb EDO (works fine on my p166) the system will not go past the boot screen at all. I have tried a total of 4 Sims on his system to no avail.
Could it be that his mobo does not support >8mb simms? Or do you think he might already have FPM and the EDO I am trying to install could be because of the conflict?
Cheers..
etech
If you have the full model number you can go to crucial and it will tell you what type of memory it takes. I'm sure the IBM site would also tell you, but I think the crucial may be easier to find it on.
IBM made a lot of Aptiva models.
viper007
Banned
Aug 25, 2000
202
Thanks heaps etech..You have solved my problems..He has FPM ram, and I am trying to install EDO!
