ilovecables
Help!
My RAM: 2x1GB low latency
Just did my first build and system works fine with one RAM stick in slot 2 (the first orange one) but when I put the second in slot 4 (matching orange for dual) it will start up but crash when barely above idle with a BSOD - "IRQL_NOT_LESS_OR_EQUAL". happens the same when I swap them: works with the other one but not the second.
I have everything at stock speeds, and the RAM is automatically loading at its recommended 2-3-2-5. FSB is 200.9
What testing should I do? Did I get a bad stick or are they in general a bad choice?
