Ram problem in P5N-E-SLI
kehnahaitumse
I purchased a new machine config being C2D e4500,ASUS p5N-E-SLI, ZION 1x2 800 Mhz ram,250Bg WD, 160 seagate hard disk,Zebronics antibiotic, XFX fidility 8600 GT.
i am facing stability problem in my mobo. How can i solve it.
JustaGeek
2,827
Set the memory to "Unlinked" 800MHz.
Set the voltage to manufacturer's specifications MANUALLY, not Auto. (ex. 2.013V)
Set the timings to manufacturer's specifications MANUALLY, not Auto. (ex. 5-5-5-15 2T Command rate VERY IMPORTANT 2T).
If you still have problems after that - come back!
And welcome to AT Forums!
JustaGeek
2,827
Get the CPU-Z and this will give you information from about the timings.
Try 5-5-5-15 2T for now.
You can try to increase the memory voltage to 1.9V, but not more than that!
If that doesn't work, put your RAM stick in the different colored memory slot (if it is the the yellow, try the black one and vice versa).
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
Is the system stable with only 1 stick of RAM in it? I had this issue with my first P5N32-E SLI Plus. One stick it was stable, with two, it wouldn't POST. Ends up it had a bad memory controller. The replacement has worked beautifully.
Shampoo
60
Could always be the possibility of that ram not being compatible with this board.
That's worst case of course.
Double check everything, connections and buy yourself a cheap power supply tester as well just incase.
I don't know if your PSU is new, but sometimes even fresh out of the box products are defective.
Hope you work it out, keep us posted!
Cheers,
Mike
Godspeed Richard Zednik!
JustaGeek
2,827
He said 1x2 800Mhz, so I assumed he had only one 2GB stick, but I think you're right.
He probably has 2 x 1GB modules...
kehnahaitumse
Right Sir, this is what i am facing. On starting it only show 800 Mhz ram with the timing. it does not amount of ram install in it.
Previously i was using 512x2 transcend 667 Mhz ,which was quite smoot in running on same set of Dimm.
Where is the problem, RAm Or mobo??
JustaGeek
2,827
Try to put them in different slots (either 2 yellow or 2 black slots).
Also, try to lower the frequency to 667MHz.
adishor
I have problems with this MOBO to
I have an P5N-E-SLI,
Gainward Bliss 9600GT Golden Sample
Intel E8200
Running Windows Vista Ultimate x64 with SP1
Untill yesterday I had 2 Gb of RAM A-Dat Vitesta Extreme PC6400.
With auto settings on latency and voltage, I couldn't even install windows vista so I set the latencies manually - 4-4-4-12 2T with 2.1 V as it said on the box of the RAM
I managed to install windows, but every time I turned on my PC after a long shutdown ( more than 30mins) I would get a blue screen, and after that all was ok.
So yesterday I changed my RAM, got 2*2Gb Kingmax PC6400, the cheap ones, most common.. and with AUTO settings in BIOS i get RANDOM system freezes.
I tried now using UNLINKED and 1.9 volts and timing 5-5-5-15 (2T) I'll post the results soon, after I do a few tests to see if it doesn't freeze or anything else.
The RAM is @ 1.8 volts but this mobo has a minimum of 1.905, could this be a problem?
adishor
It works fine with this ram, just had to set it to 5-5-5-15 2T manually and the voltage 1.9 manually, the lowest and .. no crashes, no blue screens, no nothing..
Cybercraig
328
I have 4 X 1 sticks of OCZ PC2-8500 @ 900mhz with 2.2v. I flashed to the 901 BIOS and have had no issues with it.
