- Jan 21, 2011
- 3
- 0
- 0
I've started research for the next laptop which will be a sandy machine for general use with win7. I'll probably finally make the move to 64bit. RAM is is cheap enough so there's a temptation to install 8GB instead of 4GB. Since this is for a laptop power consumption matters. Does anyone know the impact on power consumption of adding a lot of extra RAM?
Does unused RAM on a system use significant power or does it only matter when the RAM is actually being used? (Or may be extra RAM is a waste until I have specific applications designed to use it?)
Finally, there are a lot of choices of RAM with different performance. Where can I learn the tradeoffs so I'm installing the right RAM for my situation?
Any guidance on this would be appreciated.
