Originally posted by: PaidLess
Originally posted by: ElFenix
2500+ cores run at 333MHz FSBs by default. if you're running 1:1 your ram will run at the same speed as the FSB (which is 166.7). i wouldn't bother increasing the ram speed if you don't increase the FSB as well.
so that means... if i dont overclock ... my ram speed wont achieve 200mhz?
pretty much. adding ram bandwidth beyond fsb bandwidth is about as pointless as one can get. any increase in bandwidth to other peripherals is more than outweighed by the increase in latency introduced by running asynchronously.
anyway, about your overclock, you probably only have one thing, (dram clock) and then your FSB is just a fraction of that (aka they're not adjustable independently). you probably have something expressing FSB to DRAM clock ration such as 1:1 or 100%. that is fine. what you need to change is the multiplier of the CPU. a 2500 barton runs at 1833, which is 11x. that needs to be dropped to somewhere such as 10x. if you drop it to 10x, you get an easy overclock up to 10x 200mhz = 2 ghz.
now, a 2500 barton can probably take an FSB overclock to 200mhz if you bump the voltage a little and have adequate cooling.
