Hello,
1] I am currently using DDR2 Gskill 2x2Gb sticks for the total of 4GB. My current Gskill Ram is 5-5-5-15 @ 1.8V.
Now, I am only getting Transcend Ram locally (2Gb Sticks) where I am and would like to go with it, but the problem is timing and latency is not mentioned either on the Ram OR the website. (On some webpages its mentioned CAS Latency 4-5-6)
Please check and tell me the specs, Product Link:
http://www.officespecialties.com/transcend_ts256mlq64v8u_2gb_ddr2_sdram_memory_module_89953_prd1.htm
2] If I just buy single transcend 2Gb ram stick and run for the total of 6GB on my PC, is it okay? will I loose the befit of dual channel tht I am currently getting with my Gskill ram OR Gskill will run in dual channel and transcend single channel ?
