ram help with system
juggalomike
78
My system will be as follows,
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-05 - OEM
Item #: N82E16827106073
Return Policy: Standard Return Policy $35.99
SILVERSTONE SST-TJ07-BW Black 4.0mm ~ 8.0mm uni-body aluminum outer frame, 2.0mm aluminum body ATX Full Tower Computer Case - Retail
Item #: N82E16811163067
Return Policy: Standard Return Policy $329.99
Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Item #: N82E16822136011
Return Policy: Limited 30-Day Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.991 Year Service Net 1 Peripheral Extended Plan -- $39.992 Year Service Net Replacement Plan -- $39.992 Year Service Net 1 Peripheral Extended Plan -- $49.993 Year Service Net 1 Peripheral Extended Plan -- $59.99 $369.98
($184.99 each)
EVGA 768-P2-N835-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
Item #: N82E16814130079
Return Policy: Limited Non-Refundable 30-Day Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net 1 Peripheral Extended Plan -- $49.992 Year Service Net 1 Peripheral Extended Plan -- $69.993 Year Service Net 1 Peripheral Extended Plan -- $99.99 $10.00 Mail-in Rebate $589.99
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply - Retail
Item #: N82E16817139002
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.992 Year Service Net Replacement Plan -- $39.99 -$20.00 Instant
$20.00 Mail-in Rebate $189.99
$169.99
CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5DHX - Retail
Item #: N82E16820145176
Return Policy: Memory (Modules, USB) Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $39.992 Year Service Net Replacement Plan -- $59.99 $40.00 Mail-in Rebate $254.00
GIGABYTE GA-X38-DQ6 LGA 775 Intel X38 ATX Ultra Durable 2, Ultra Cooling Intel Motherboard - Retail
Item #: N82E16813128066
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $39.992 Year Service Net Replacement Plan -- $59.99 -$20.00 Instant
$299.99
$279.99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
Item #: N82E16819115017
Return Policy: Processors (CPUs) Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $39.992 Year Service Net Replacement Plan -- $59.99 $279.99
however the ram i was going to use, which is listed above as CORSAIR XMS2 4GB(2 x 2GB) is sold out on newegg, and i cant seem to find it on any other sites, does anyone have reccomendations for a ram that is comparable if not better then this? that would work with my system, or another place to buy that ram
juggalomike
78
yeah both are OOS, is this a hard to find RAM? it was instock on newegg forever then it just went OOS a few days ago, said expected in the 26th and now it doesnt say when its expected in
