- Feb 4, 2003
- 35
- 0
- 61
Haswell doesn't make a lot of heat, but it has difficulty getting it away from it's components because the cap on the chip is such a good insulator. Because of this, the most voltage you can hope to run air cooled is 1.30V. Otherwise the internal temp is going to be 90C +
1) Set bios values to optimized default
2) Set cpu adaptive voltage to 1.30V
3) Set all cpu cores to the same multiplier and start working up 42x, 43x, 44x, 45x etc.
4) Stress test with prime95 and Aida64 simultaneously.
5) Once you crash or fail, drop the multiplier down and see what you can run overnight - This is your max stable overclock multiplier
6) Drop the voltage down .01V at a time while running your max stable overclock multiplier until you fail AIDA/Prime - Raise it back up to what was stable so You know now what your minimum adaptive voltage necessary is.
7) Use your minimum stable adaptive voltage and subtract 2 from your max stable multiplier so you have a nice stable system. Subtract 3 if you want extra extra safety margin.
All done with a minimum muss and fuss! We didn't throw away all of those cool power saving features of Haswell either with locked voltage, and the cpu and other components should last much longer with this strategy. Also, you don't spend a week testing every weird option in the bios for an insignificant performance boost.
I'm running a i5-4670k on a Asrock Z87 Extreme4 MB with CoolerMaster 212 Evo heatsink.
My max multiplier is 44x at 1.298V
I run the machine at 41x
