Raidmax Smilodon Cooling
dr0be
197
I plan on buying this Raidmax Smilodon case for my new PC I'm building and I had a quick question so I know how many fan filters I should buy. Normally with a case id just had the front fan intake and the rest blowing out. This case has...
- 1 rear 80mm
- 2 window side 80mm
- 1 motherboard side 80mm
- 1 front 120mm
- Buying a PCI Slot fan to put below my 8800GTS
Which would you suggest blowing in and which out? The front is obviously intake but what about the rest? I asked because I doubt only the front will work seeing how there is a door which probably limits the intake amount.
*edit* Also the zalman CPU HSF im buying can be mounted facing any direction, so what would be the best direction among the case fan setup?
VinDSL
4,869
www.lenon.com
Personally, I don't like fan filters (I like air compressors/blow guns) so... no recommendation from me...
However, ALL of the fans on a Smilodon should be used for intake, except the rear exhaust.
Watch Rod's video and listen for the words 'intake' and 'exhaust'... ;)
