RAID5 using USB drives
Azra
Is it possible to create a software RAID5 array in Windows 10 Pro using USB drives?
Like Seagate Backup Plus Portable 4TB drives. I have a bunch of those and I'd like to put them to good use. But I can't erase the data that's on them just yet and I don't have Windows 10 installed yet on my target computer so I figured I'd ask before making plans.
Thanks!
Feb 25, 2011
17,000
1,628
Yes. However, you have to trick the system into thinking they're not removable.
http://reboot.pro/topic/10534-converting-usb-removable-to-fixed-disk-bcdedit-menu-list/
Once you have the USB Removable flag unset, you can use Disk Management to create a software RAID.
That said, if you already have data on the disks, I'm 99% sure that combining them into a RAID5 configuration in Disk Management will require you delete all the data on them.
Reactions: Azra
Mark_Venture
29
Azra
I didn't know about Storage Spaces. It should solve my problem perfectly. Thank you Mark.
