I just set up my SATA Drive and had to go under nForce's RAID Utility to set it up. At the time I did not know what settings to select so I choose RAID 0 (Striping).
I installed XP using the 3rd party drivers, changed BIOS to boot on SATA Drive, and everything seems to be working fine.
I then was reading the back part of my manual (yes.. I play first, read manual later 😛 ) but I found a part then when setting up a single drive, I should choose the JBOD option.
My question is since I am using a single drive, will the RAID 0 option interfear with anything down the road and do I need to reset the RAID funtion or can I leave it as is and since I only have 1 Drive set up for RAID 0, it will work fine.
Thanks!
Thanks!
