I am using the DFI LANPARTY UT nVidia nForce3 250Gb motherboard with two 200 GB western digital hard drives in mirrored raid. Everything was fine (running withoug problems for 3 weeks) until I ran Norton 2004's speed disk (defragmenter) on drive C: (both drives). After defragmenting and rebooting the RAID status has changed from "heathy" to "degraded". The computer now is EXTREMELY slow. Windows also now sees two seperate drives. What can I do to fix this? Will I have to select the "rebuild" option in the RAID menu to correct this? If so, which drive do I select to rebuild? Also, in the future, how do I defragment the drive(s) so don't encounter this problem? Should I only use Windows disk defragmenter and not Symentec's speed disk? Symantec noted that speed disk should have treated both drives as one since it's the newest version. Please help.
Antec Sonata w/430W
AMD 64 3000+
DFI Lanparty UT nvidia nForce 3 250GB
1 GB PC 3200 Corsair RAM
2 (Mirrored) SATA Western Digital 200GB HDDs
Antec Sonata w/430W
AMD 64 3000+
