RAID 1 Degraded, help please :)
mrissmann
24
Good day,
I have a DFI LANPARTY UT nF4 Ultra-D Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard setup working since 6/2006 with the following drive setups:
c: single 80gb lDE drive,
d: a 250gb SATA raid 1
e: a 400gb SATA raid 1
When I boot up I am told that my 250gb raid is degraded. I replaced one of the drives and rebuilt. (Any way to know what drive is causing the problem?) Everything worked fine for a couple of days, now I am getting the degraded array warning again.
Any thoughts?
-Markus
JDMnAR1
11,984
If you don't have any kind of diagnostics available to you when you are booted into your OS, there should be a key combination at boot-time that will allow you to go into your RAID configuration manager. Typically you can verify drive status within there, but I have no experience with your particular setup.
