I was playing around with a computer I have. I put a new CPU in it and it was fine after a couple of week I started to overclock it .. I went over the edge and the computer kept cycling rebooting .. so I pulled the jumper , reset the bios and everything was fine.
I kept notes on what I was doing and headed back towards the edge again with the memory. The CPU overclocked with no problems. So I'd fall off the edge again and reset it and start over. Then something different happened about the 4 time I did this . It will not boot the raid 0 array (2 drives).
I wondered if I toasted something on the motherboard so I put an old XP set of drives I had in the computer (also setup as raid 0 ) and it booted and ran fine. The computer's board is fine .. so that is not the problem.
Is there a program that I can boot off of a CD or DVD that I can use to repair the raid 0 array ? I'd like to fix it if I can.
