It's a Sony GDM-FW900. It is an unusual res and I can't find it listed as a supported resolution for that card so I thought a 9800 owner might go to desktop settings and have a look.
It doesn't appear to be listed as a standard resolution that I can select -- but I'm certain the card can physically do it. It would probably show up if the monitor's EDID data says that is a supported resolution. Worst case is you would have to do it as a custom resolution using Powerstrip.
I've run the monitor at that res with a GeForce 2 GTS and GeForce 4 Ti4600 without powerstrip. I guess ATI is just a little different. Thanks for the information.
