Radius Tru-Tune Ultra-light Aluminum Earbuds W/ Noise Isolation, iPhone Compatible - Matches 3G Blue Nano #RA-HP01BL
Pardus
8,197
21
Radius Tru-Tune Ultra-light Aluminum Earbuds W/ Noise Isolation, iPhone Compatible - Matches 3G Blue Nano - RA-HP01BL
Price: $9.99. Free ship. Tax where applicable.
Manufacturer: Radius
Mfg Part#: RA-HP01BL
UPC: 00689466068399
Buy.com Sku: 209856584
Item#: E4FJN2
Made for you in as many shades as there are personalities, Radius TruTune earphones set a new standard for fashion and fidelity. From the satin aluminum casing to the sleek, soft cable, these Japanese-designed earphones are thoughtfully crafted inside and out throughout, so your music sounds as good as you look.
The Radius design is personified in the TruTune line of earphones. Blurring the lines between ?sound gear? and ?fashion accessory?, TruTune is stylish, unpretentious and universally affordable. The available colors ensure a spot-on match for your music player or your aura.
Tech Specs
Dynamic Driver 10mm
Neodymium Magnet 9mm
Stereo Mini Plug 3.5mm
Mini extension 42?
Frequency Response 20Hz-20kHz
Sensitivity (1KHz, 0.1V) 103dB
Impedance 16O
funboy6942
15,315
395
These are the EXACT same ones from DX for $3~ shipped in orange.
Linkage to what Im talking about, check the pictures out.
The plug in at the end is the same, including the color of the seperator, just these are in Orange. I dont find them to be all that bad, other then to get the best sound out of them you have to kinda move them around in your ear to find the "sweet" spot.
But I may be wrong, but holding these in my hand, and looking at the pics, Im prolly 99.99% on the money that these are the same, even done up in aluminum as well too. For $10 you can get them a hell of a lot quicker then if you bought from DX right now, so not too bad of a find, but they do not sound all the best, but for $3-$10 they are not too bad, Ive heard and own much worse in search of the perfect cheap headphones that dont need a batery like my Headbangers do. I just have yet to find anything that can sound as good as them in the $20 range for I will never spend more then that on a head set :)
