Radio Presets Gone, Getting Harder to Start: Battery Dying?
Status
Not open for further replies.
axelfox
6,719
Just recently my aftermarket radio (installed for several years now) has had the radio station presets reset to factory presets. Furthermore, the radio does not turn on when I start the car (previously it did).
I did notice that my car took just a little longer to turn over the other day. Other than that episode, I have had no problems starting my car.
Perhaps it's just a coincidence, but one of the flaps on my AV vent broke off and fell back inside the car down the AC "tube". The radio problems began short after this happened. I don't know if it's the cause, but I figured I would just mention it.
I figure I just might need to replace the battery, but I want to get the thoughts from the Garage first.
1998 Rav4, will be taking it in for its 150K tune up soon as well.
Thanks.
SuperSix
How old is it? There's a date code somewhere. Like "A4" (January '04) or something similar. 3-4 years (depending on climate) is the average useful life for a car battery.
Spungo
3,217
I would guess that starting the car drops the voltage low enough to clear the memory. Go buy a car battery tester. I think I paid $10 for mine when it was on sale.
Vetterin
973
Autozone or Advance Auto will do a free load test on it and you will know for sure.
Status
