- Dec 30, 1999
- 6,324
- 10
- 81
I've got an old 93 Prelude Si h23a I still keep it as it drives good, it's seen better days but going point A to B it still does it's job . The bottom radiator hose cracked and so they replaced it, problem is now there is no heat in the cabin.
I googled and it said air might be trapped in, the mechanic said it was bled correctly. What else could it be? Seems odd the thermostat could go bad right then. If I get no heat in the cabin does it mean the engine is still getting cooled properly (that's my main concern, my car's dashboard has an electric temp gauge that stopped working long ago). I can live without the heat, I just need the engine to be properly cooled.
