- Oct 11, 2000
- 56,336
- 11
- 0
Symptoms:
- there are two fans: radiator and A/C
- when A/C off, radiator fan does not turn on automatically
- when A/C is turned on, both fans turn on and off at the same time automatically
- engine temperature gauge shows close to overheating (assumed to be correct as temperature gauge appears working when car is warming up)
- turning on A/C appears to bring down the temperature shown on the temperature gauge
Troubleshooting Steps Performed:
- radiator coolant was flushed and refilled
- checked relay fuses to radiator and A/C fan
- unplugged the temperature gauge connector (next to coolant temperature sensor) in engine bay. Gauge on dashboard unresponsive.
- unplugged the coolant temperature sensor in engine bay. "Check Engine" light on dashboard comes on.
- warmed up the car to normal temperature with radiator cap off to see if radiator fluid was circulating. Inconclusive due to car shakiness.
- gauged temperature of top and bottom radiator hoses by hand. Both seemed to be equally hot, although, turning on A/C seemed to make bottom hose slightly cooler
Possibly Relevant Info:
Car is a 1994 Toyota Camry 4-cyl.
Question:
Which could it be: thermostat, coolant temperature sensor, or other?
EDIT: Added more troubleshooting steps performed.
Question:
