Radiator Fan Blade Nut.. Advice (Pix)
Status
Not open for further replies.
blipblop
So one of my radiator fans has been off the hub of he fan motor since September of last year and I've never bothered to fix it... Car in question is a 2005 Scion tC
I got around to taking those clips off and I see this... I thought it would be pretty simple as in I can screw it back on via a nut or something, but I have no idea how the fan attached itself to the motor!
Any help would be appreciated . . .
Here are the front and the back of the fan. Should I replace the entire shroud that includes the a/c fan? That one works without any issues.
I found the fan blade nut and purchased one at a local dealer... but I still think I'm missing something since I'm not sure how the fan bladis held on to the motor.
The fan blade nut does not seem big enough, but the part number is right... Freaking A...
Thanks
Status
