Could you take say 1/8th inch copper tubing and create a coil around the sides of a case and then find a way to pump a coolant through it and lower the ambient temp in the case? I guess you'd call it radiant cooling.
lol unfortunately that would put too much strain on the fridge trying to keep it at the temp I set would probably kill the compressor. Plus i'd like to be able to add the cpu and gpu to the loop.
The problem is regardless of how good the seal is the components generate heat. Which is the equivalent of leaving the door open. Also in a sealed unit the hot air has no where to go.
Doesn't work. A refrigerator cannot keep up with the heat output.just buy a small fridge and put the computer in it 😀
If you want extreme cooling, use the compressor and stuff from a mini-fridge and make a phase change cooling system. You'll get really cold temps for the fluid flowing through your waterblocks.
Compressors from mini-fridges have been used by a few people with success. There's a guy on Extremeoverclocking.com that used one. It kept his AMD X2 3800 at sub zero temps, but he was a fool and he got condensation which fried his components. I'm sure it crapped out after a while too, because that's a lot of load for a small compressor. I'm just saying, it will work. I agree a stronger compressor should be used liked you mentioned -- the ones from air conditioning units or other active cooling products.no your not suposed to use a compressor for a fridge period.
Fridges are not meant to cool something. There meant to keep something cold.
Completely different aspect your looking at.
If you want to butcher a unit for the compressor, a simple window AC compressor is 100x better since they have longer duty cycles.
