Radeon9800pro/agp runnin hot
justbuildit
Anyone know why the Radeon 9800pro agp,is running so hot on my computer,,i mean you can touch the mini heatsinks on it and get burned? am confused,i have a 500/w ps..any suggestions would help thank you or does anyone know if this is normal for the ATI/Radeon family ?🙂
Will you literally get burned or is it just very hot? My 9800 pro, if I remember correctly, was hot to the touch as well. But that was after a few hours of playing Doom 3.
As long as it is running at stock voltages, it should be fine. In fact, I believe that it does not even have RAMsinks normally (I am guessing that is what you mean by mini heatsinks, there would be 4 on each side of the card)
If you really want the card to run cooler, I would reccomend an ATI Silencer for it - not only will it be cooler, it will also be quieter.
I would also recommend the VGA silencer for it,that stock heatsink/fan is a joke.
