Radeon vs FireGL vs Quadro vs GeForce
lambchops511
659
Right now I am writing a custom application (utilizng OpenGL 2.0)
Specifically I am only using PBO and Textures .
There won't be any complex calculations
The app is basically: Move data from ram to PBO to texture to frame buffer
However, the texture and pbo sizes are quite large (1920x1080) and i need to produce extremely high rates ( 120...later on 240 )
which type of video card do u recommend?
I am noticing quite a performance (~2x) difference between Quadro FX 1500 PCIE and ATI Radeo 1650XT AGP . Could this be because of the bus? or the card?
Munky
9,372
The bus will limit your performance if you're transfering large amounts of data from system ram to the video card.
lambchops511
659
i need a sustained transfer rate of 750MB/s (unidirectional)
shouldnt AGP be good enough for that?
Munky
9,372
AGP 4x and up would allow that. Note, however, that the performance also depends on how you code and how well the driver is optimized for cpu->gpu transfer.
lambchops511
659
my code bypasses the CPU
its DMAed directly from memory to vram (thats why i said i was using PBO)
so u think the performance difference is the card? or the bus?
Jan 31, 2002
40,819
A little of both IMO.
Given the sustained bandwidth you're requesting, PCIe should give a bit more overhead.
Also, I'm probably going to get flamed for this, but nVidia's OpenGL implementation always seemed to have been a little more on the ball than ATI's. That's just my personal experience.
- M4H
40sTheme
1,607
- M4H
No, you're not in the wrong there, nVidia consistently outperforms ATi in OpenGL applications.
Gamingphreek
11,679
As for which card....any of them will be fine. The Quadro's and FireGL's really big main difference (outside of various optimizations) is line-anti-aliasing. Therefore any of them will be fine.
-Kevin
CP5670
5,660
762
I would think that the gamer cards will be faster here if they're all on PCIE. Most of them have less but faster memory than the equivalent professional ones.
lambchops511
659
hmmmmm
do u think the professional cards will be better?
i dont have any antialiasing going on . however, (believe it or not) the NVIDIA OpenGL 2.0 implementation of PBOs are bugged . after a certain size with rgb textures it crashes . ati works fine
i am leaning towards a FireGL card . do u think it'll be better than the Radeon card?
memory bandwidth means nothing to me . since almost no data is stored on the vram . it is almost direct dma from ram to framebuffer
lambchops511
659
i just ran my test on a x1950xtx
it produced the exact same rates as the x1650pro
the quadro card is MUCH faster
do professional cards make that much of a difference?
